Re: [Nagios-devel] Nagios Event Broker Duplicated Events
------_=_NextPart_001_01C6D756.30329949
Content-Type: text/plain;
charset="us-ascii"
Ooops,
=20
I think I might have figured this one out....
=20
NEBCALLBACK_HOST_STATUS_DATA (unprocessed) --> Nagios -->
NEBCALLBACK_HOST_STATUS_DATA (processed)
=20
events are generated on each.
=20
Anyone correct me if I'm incorrect in this assumption.
=20
If the above assumption is correct, where can I test to see if I'm
dealing with a "processed" event?
=20
thanks,
Nick
________________________________
[mailto:[email protected]] On Behalf Of
Nicholas Whiting
Sent: Wednesday, September 13, 2006 10:55 AM
To: [email protected]
Subject: Re: [Nagios-devel] Nagios Event Broker Duplicated Events
=20
Thanks for the reply Ton,
=20
This is a possibility but when I extract data from
nebstruct_host/service_status_data I am able to retrieve
service check output/perfdata information. How would this be possible if
I intercepted a check that was
about to be performed(started)?
=20
Is there somewhere I can check to see if I am dealing with a "processed"
service check?
=20
nick
=20
[mailto:[email protected]] On Behalf Of Ton
Voon
Sent: Tuesday, September 12, 2006 6:34 PM
To: Nagios-Devel
=20
There are two broker calls for each event - a start and a stop. Could
you be processing both?
=20
Ton
=20
On 12 Sep 2006, at 17:10, Nicholas Whiting wrote:
=20
=20
I have completed the preliminary coding of an event broker that listens
for
NEBCALLBACK_HOST_STATUS_DATA and NEBCALLBACK_SERVICE_STATUS_DATA
events. The module then extracts the details for these events from
corresponding=20
nebstruct_host_status_data and nebstruct_service_status data and
generates XML output
which is then passed to a customized messaging stack.
=20
Anyways, my issue is that these events appear to duplicate. I receive
what looks like 2 duplicate
events for each host and service check data event. The extracted data
are identical in both events.
=20
Can anyone suggest any subtleties in these events that will allow me to
ignore one rather than pass
both up to the messaging stack?
=20
Nick
=20
This message has been scanned for viruses by MailController
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=3Dl ... 57&dat=3D=
121642
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
=20
=20
=20
http://www.altinity.com
T: +44 (0)870 787 9243
F: +44 (0)845 280 1725
Skype: tonvoon
=20
Content-Type: text/html;
charset="us-ascii"
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
...[email truncated]...
