Oh sorry I meant --with-command-group=
This should do what you want.
Thomas
On 02/05/07 07:11 AM, Michael Lubben wrote:
> No, i don't use this option. Default is the group nagios, but you must create a group with nagcmd with members nagios and the user from your webserver. This in write in the documantion. Better was then as dafault group nagcmd.
> Bye
> Michael
> -----Ursprüngliche Nachricht-----
> Von: Nagios Developers List
> Gesendet: 02.05.07 11:53:22
> An: Nagios Developers List
> Betreff: Re: [Nagios-devel] Bin in make install-commandmode
> On 02/05/07 02:53 AM, Michael Lubben wrote:
>> Hi Ethan,
>> i have found a little bug in "make install-commandmode". When i excuted this command, follow instruction i can see on the display:
>> /usr/bin/install -c -m 755 -o nagios -g nagios -d /usr/local/nagios/var/rw
>> chmod g+s /usr/local/nagios/var/rw
>> For the external commandfile is set the group nagios. That is not right, the group must be nagcmd.
> Are you using --with-nagios-group=nagcmd in your configure arguments?
> Thomas
