similar functionality for servicegroup matching as well.
On 24 Mar 2004 at 13:36, Matthew Kent wrote:
> This small patch is mainly to make negation (thank you for this very
> handy feature
> It allows for these small/lazy definitions to be formed like so:
> define service {
> use service-critical
> hostgroup_name *,!remote,!tunnel
> service_description PING
> check_command check_fping!50.0,0%!100.0,25%
> define service{
> use service-noncritical
> hostgroup_name remote,tunnel
> check_command check_fping!500.0,0%!10000.0,60%
> Handy if you have many hostgroups defined.
> Diff'ed against rev 1.71
> Thoughts?
> Matthew Kent \ SA \ bravenet.com \ 1-250-954-3203 ext 108
Ethan Galstad,
Nagios Developer
Email: [email protected]
