[Nagios-devel] Patch: Sourcing Passive check results from a database
This is a multipart MIME message.
--==_Exmh_-2444528180
We have around 3000 passive checks going (all the data collection is
done by another program, eddie [www.eddie-tool.net], which runs on the
hosts being monitored) so we found it more reliable to have the passive
check results get put into a database, and only deleted from that
database when nagios had processed it.
We use mysql so I haven't been able to test it with postgres, but,
fingers crossed, it should work, maybe.
Dougal Scott Connect Internet Solutions
[email protected] 9/114 Albert Rd
Senior Systems Administrator South Melbourne, Australia, 3205
Content-Type: text/plain ; name="xpasv.h"; charset=us-ascii
Content-Description: xpasv.h
Content-Disposition: attachment; filename="xpasv.h"
* XPASV.H - Header file for database status data routines
* Copyright (c) 1999-2001 Ethan Galstad ([email protected])
* Last Modified: 06-22-2001
* License:
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
#define XPASV_PASSIVECHECKS_TABLE "passive_checks"
#define XPASV_BUFFER_LENGTH 1024
#define XPASV_SQL_LENGTH 2048 /* buffer length for SQL queries */
int xpasv_check_connection(void);
int xpasv_reconnect(void);
int xpasv_begin_transaction(void);
int xpasv_commit_transaction(void);
int xpasv_rollback_transaction(void);
int xpasv_optimize_tables(void);
int get_passive_checks_from_database(void);
int xpasv_escape_string(char *,char *);
int xpasvdb_grab_config_info(char *);
void xpasvdb_grab_config_directives(char *);
int xpasvdb_initialize(char *);
int xpasvdb_connect(void);
int xpasvdb_disconnect(void);
int xpasvdb_query(char *);
int xpasvdb_free_query_memory(void);
Content-Type: text/plain ; name="xpasv.c"; charset=us-ascii
Content-Description: xpasv.c
Content-Disposition: attachment; filename="xpasv.c"
* XPASV.C - Database routines for passive checks
* Copyright (c) 2000-2002 Ethan Galstad ([email protected])
* Last Modified: 05-27-2002
* License:
/*********** COMMON HEADER FILES ***********/
#include "../common/config.h"
#include "../common/common.h"
#include "../common/locations.h"
#ifdef NSCORE
#include "../base/nagios.h"
#endif
#include "xpasv.h"
/**** IMPLEMENTATION SPECIFIC HEADER FILES ****/
#ifdef US
...[email truncated]...
