remove ghost service
diegosiassb
Post by diegosiassb »
I have the following problem and I can not find a solution.
I removed two check, which I used to check the two links.
One of the check is left. Now I can not remove the check because it is not present, but in the service problems and is visible in red.
I have tried to restore the backup ,but, the problem remains after ten minutes that everything seems settled the error reappears. How do I delete it?
Diego
diegosiassb
Re: remove ghost service
I checked the mysql database (nagiosql), and I dont't found this definition.
I do not know where I can keep this up
diegosiassb
Sorry my version is Nagios XI 2009R1.4B
Bye
Diego
rdedon
Post by rdedon »
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
