Re: [Nagios-devel] Leading space in continuation lines
--Apple-Mail-25-783927830
Content-Type: text/plain;
charset=US-ASCII;
format=flowed;
delsp=yes
On 17 Jun 2009, at 05:19, Ethan Galstad wrote:
> Holger Weiss wrote:
>> * Gerhard Lausser [2009-05-02 13:49]:
>>> I attached a patch for base/utils.c(mmap_fgets_multiline) (v3.10)
>>> which cuts
>>> off leading white space from continuation lines.
>> Of course, this breaks configurations which do stuff like
>> command_line $USER1$/check_foo one\
>> two
>> and expect to get this parsed with white space between "one" and
>> "two".
>> However, this incompatibility is probably negligible, and I guess
>> most
>> users would prefer if leading white space was stripped from
>> continuation
>> lines.
>> So, I'd appreciate if the patch was committed. I've attached a
>> version
>> of the diff which updates cgi/cgiutils.c:mmap_fgets_multiline(), too,
>> and which simplifies the code a bit.
>> Holger
> Thanks - patch is in CVS.
While testing C code is pretty hard, testing configuration parsing is
very easy. See http://wiki.nagios.org/index.php/Develo ... file_tests
for instructions.
I've committed a test case for the config generation based on Gerhard
and Holger's examples.
So please consider this a little plea to add tests for patches when
doing changes around configuration files :)
Ton
Content-Type: text/html;
charset=US-ASCII
On 17 Jun 2009, at =
05:19, Ethan Galstad wrote:Holger =
Weiss wrote:* Gerhard Lausser <[email protected]> =
[2009-05-02 13:49]:I attached a patch for base/utils.c(mmap_fgets_multiline) =
(v3.10) which cutsoff leading white space from =
continuation lines.Of course, this =
breaks configurations which do stuff like =
command_line $USER1$/check_foo one\ =
            &n=
bsp;           &nbs=
p;     twoand expect to =
get this parsed with white space between "one" and =
"two".However, this =
incompatibility is probably negligible, and I guess =
mostusers would prefer if =
leading white space was stripped from =
continuationlines.So, I'd =
appreciate if the patch was committed.  I've attached a =
versionof the diff which =
updates cgi/cgiutils.c:mmap_fgets_multiline(), =
too,and which simplifies the =
code a bit.HolgerThanks - patch is in =
CVS.While testing C code is =
pretty hard, testing configuration parsing is very easy. See <a =
href=3D"http://wiki.nagios.org/index.php/Develo
...[email truncated]...
