> Hi list,
> I'm curently writing a new algo for hostdependency (and service) like
> for the circular host check. I wrote it, but I've got a different
> result than Nagios for this conf :
> host1 inherit on the last dependancy.
> My algo say this is not a problem, because the last relation is
> without inherits (so we do not cycle), but Nagios is not OK with it.
> I'm wrong?
looks like the current implementation recursively checks the
dependencies regardless of whether they inherit their parents or not.
in my opinion this is the right behavior, even though the runtime may
not recursively check dependents (depending on inheritance), defining
circular dependencies in configs should be wrong.
if the others agree with this, it could be nice if the new algorithm
checked for this, and still is faster than the current
> You can test with the sample conf, untar the file in
> /usr/local/nagios/etc/ and add into the nagios.cfg :
> cfg_file=/usr/local/nagios/etc/host-10000.cfg
> cfg_file=/usr/local/nagios/etc/service-10000.cfg
> cfg_file=/usr/local/nagios/etc/host-dep-10000.cfg
> If my algo is OK, it's quite fast for huge conf with a lot of inherits
> dependancies. If not, it's quite fast for find false results :p
> Thanks,
