Shad L. Lords wrote:
>>>> Finally in trying to duplicate this I was trying to come up with a
>>>> minimal
>>>> config and found one that would cause a Segmentation fault during
>>>> checking
>>>> contacts.
>>> I tested this tiny config and it worked okay - got warnings about
>>> missing timeperiods and it didn't segfault. Try the latest CVS when you
>>> get a chance to see if that fixes any problems you were having.
> Here is a backtrace that I was able to produce. Hopefully I did it right.
> Also hope it will be of use:
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread -1208248640 (LWP 16595)]
> 0x00a5413b in strlen () from /lib/i686/nosegneg/libc.so.6
> (gdb) bt
> #0 0x00a5413b in strlen () from /lib/i686/nosegneg/libc.so.6
> #1 0x08080fdd in hashfunc (name1=0x20676e69 bounds>, name2=0x0, hashslots=64) at utils.c:3053
> #2 0x0808fff2 in find_timeperiod (name=0x20676e69 of bounds>) at ../common/objects.c:2891
> #3 0x080611b2 in pre_flight_object_check (w=0xbffca108, e=0xbffca104) at
> config.c:2151
> #4 0x0806261c in pre_flight_check () at config.c:1466
> #5 0x08056a1c in main (argc=Cannot access memory at address 0x1
> ) at nagios.c:516
Fix is now in CVS. Thanks!
Ethan Galstad,
Nagios Developer
Email: [email protected]
