Re: [Nagios-devel] nagios 2 + DB support, coming soon to a SF mirror
What are you trying to accomplish by running multiple Nagios instances?
Each instance *could* point to the same database, but if the configuration
options that nagios-db copies are different between the instances (things
like "enable flap detection"), or if there are overlaps in object names,
then that would lead to confusion.
Each instance could also point to its own database on the same server, but
then of course the instances know nothing about each other. But that's
kind of what you have right now...... I think.
Anyway, there aren't any concurrency issues, if that's what you're asking.
But I don't see what you get out of running multiple instances instead of
a single instance, other than isolation... which you could get just as
easily by having multiple databases on the same server.
On Thu, 23 Dec 2004, Jason Martin wrote:
> On Wed, Dec 22, 2004 at 09:54:49PM -0800, Ben wrote:
> > So.... if the idea of being able to pull up an overview page for 10k
> > services in about 2 seconds sounds appealing to you, enjoy this code. :)
> By any chance would this work w/multiple Nagios instances
> pointed to the same DB?
> -Jason Martin
> "No good deed goes unpunished" - Clare Booth Luce
> This message is PGP/MIME signed.
