Re: [Nagios-devel] lost trends in nagios-cvs?
On Sun, 13 Nov 2005, Andreas Ericsson wrote:
> This is because the configure script doesn't pick up your GD installation
> (although it should build statuswrl regardless).
I'm not sure. When I access to URL /nagios/cgi-bin/trends.cgi?xxx
directly, it draws nice graph.
> Where is your gd-library installed?
I'm using Debian GNU/Linux with libgd2-noxpm and libgd2-noxpm-dev
packages. So libraries are in /usr/lib/ and headers in /usr/include/ :
/usr/lib/libgd.a
/usr/lib/libgd.la
/usr/lib/libgd.so
/usr/lib/libgd.so.2
/usr/lib/libgd.so.2.0.33
/usr/include/gd.h
> Did you pass it as an option to ./configure ?
no (as in 2.0b4 version, where this problem does not exist).
When I run ./configure (without any parameters), it writes:
checking for gdImagePng in -lgd (order 1)... no
checking for gdImagePng in -lgd (order 2)... yes
GD library was found!
And when I tried to call configure with gd options just now:
./configure --with-gd-lib=/usr/lib --with-gd-inc=/usr/include
then include/cgiutils.h is same - with /* #undef USE_TRENDS */
Milos
