> Thanks for the pointer on the future Ethan, I am not sure how many of the
> Netsaint/Nagios users out here are using the database support, but it seems
> to be a reasonable number. Would you envisage us adding database support as
> a 'patch' or might you consider providing an API against which we could
> implement any other 'storage service' that we might want to play with.
> I guess that the alternative might be for someone
> SQL-->Files bridge (mmmm sounds a bit like mSQL v 0.1) for those who still
> want/need db support.
> Personally I am playing with the database as the files get a little clunky
> when writing other analysis code and or interfaces to monitoring/management
> systems other than Nagios
> are much faster (to code and to perform), especially when log-file rotation
> (archiving) is enabled.
> Where can the community add most value here ?
> Mark
I think the config files are files for what Nagios needs from it - an
initilization. A DB -to- config generator could be built very easily
allowing you to maintain you configs in the DB yet use Nagios.
On the log aspects, I tend to favor an option of DB with a single column
table for each entry in addition to the flat files and archive methods.
DB does provide a certain flexibility in generating and sorting for
reporting purposes.
-sg
