[Nagios-devel] Embedded Perl feature request
I see that Ethan has done some checkins regarding the embedded perl
features. I wanted to add one suggestion that I emailed out once
previously but had no response.
The path to p1.pl (the file embedded perl appears to use) is hardcoded
in locations.h after you run configure. If you ever want to move
anything around, have multiple instances with separate p1.pl files, etc,
you would need to re-configure and re-make, so it's not very portable.
Can you add a line to the nagios.cfg to specifiy where the p1.pl file
lives and have Nagios read it from the cfg instead of the hardcoded
value in locations.h. Thanks.
-Russell
Russell Scibetti
Quadrix Solutions, Inc.
http://www.quadrix.com
(732) 235-2335, ext. 7038
