Re: [Nagios-devel] SEGV in 2.0b2 (FreeBSD 4.10/200 hosts/330 active/300 passive) - repeatedly after 2-7 days running.
Thanks for the note Stanley. If you can manage to get a core file or
track the problem down further, let me know. I'm releasing 2.0b3
tonight, so this won't probably be fixed until 2.0b4.
On 2 Apr 2005 at 19:53, Stanley Hopcroft wrote:
> Dear Folks,
> I am writing to report what may be a problem with Nag 2.0b2 (embedded
> Perl, pthread lib, FreeBSD 4.10).
> Nagios runs no more than 10 days before dieing with a SEGV.
> Like a former report of SEGVs ('coredumps in wobbly
> networks'/Ericsson/24 Mar 2005) there _may_ be a pattern in the logged
> messages before the SEGV.
> Exitting from scheduled downtime appears to be a health hazard.
> In the last case,
> Sat Apr 02 17:05:42 SERVICE DOWNTIME ALERT:
> foo:bar via the blurfl provider
> infrastructure;STOPPED; Service has exited from a period of scheduled
> downtime Sat Apr 02 17:06:18 Auto-save of retention data completed
> successfully.
> Sat Apr 02 18:07:33 Nagios 2.0b2 starting... (PID=97771)
> tsitc> grep nagios /var/log/messages
> Apr 2 17:07:52 tsitc /kernel: pid 3400 (nagios), uid 1000: exited on
> signal 11
> And the one before,
> Tue Mar 29 06:20:58 SERVICE ALERT: nada;TEC CPU;WARNING;HARD;1;The
> percentage of CPU in idle state is low. This indicates high CPU
> overload. date: 03/29/2005 06:20:50 AM eventid: 1112041070 557
> modelname: DMXCpu name: total percidlecpu: 0 profilename:
> ITM.OS.Unix_Dev_Monitoring.itm#IPAustralia-region source: TMNT status:
> OPEN
> Tue Mar 29 06:30:44 SERVICE DOWNTIME ALERT: yada;Standard host-centric
> checks;STOPPED; Service has exited from a period of scheduled downtime
> Tue Mar 29 06:30:44 SERVICE DOWNTIME ALERT: wurfl;COMS ad-hoc
> check;STOPPED; Service has exited from a period of scheduled downtime
> Tue Mar 29 06:30:44 HOST DOWNTIME ALERT: yada;STOPPED; Host has exited
> from a period of scheduled downtime Tue Mar 29 09:11:27 Nagios 2.0b2
> starting... (PID=5473)
> Mar 29 06:30:44 tsitc /kernel: pid 31467 (nagios), uid 1000: exited on
> signal 11
> Obviously it is easy to check whether scheduling downtime is causal; I
> will give it a go and watch.
> No core file.
> Yours sincerely.
> Stanley Hopcroft
> IP Australia
> Ph: (02) 6283 3189 Fax: (02) 6281 1353
> PO Box 200 Woden ACT 2606
> http://www.ipaustralia.gov.au
Ethan Galstad,
Nagios Developer
Email: [email protected]
