Nagios 3.2.1
I know that you can disable all notifications for a system by going into Process info in the UI and disabling it there, is that action logged to a file anywhere?
Disable all notifications
tonyyarusso
Re: Disable all notifications
Yes, in the nagios.log file - it will look like this: "[1299084152] EXTERNAL COMMAND: DISABLE_NOTIFICATIONS;1299084151".
Is there some type of logging level that you would need to be at to see that? I do not see anything that matches that description.
As a work around, it looks like in the access.log when you disable notifications, it shows an entry there for "cmd_typ=11" that seems to correspond to a user disabling notifications. cmd_typ=12 seems to be for enabling notifications after they have been disabled.
This would be the path:
cd /usr/local/nagios/var
there are no entries that match that format when I know that I have disabled alerts within the logs time frame.
(Also, this message was moved from another forum, could it be placed inside the Core section as that is what it's regarding?)
