This is a multi-part message in MIME format...
------------=_1101444825-49642-6
Content-Disposition: inline
Dear Sir,
I am writing to thank you for your letter and say,
On Fri, Nov 26, 2004 at 09:42:46AM +0530, ashraf wrote:
> hi
> dear friend s
> i am new to this nagios i installed nagios also installed plugins some
> waht it is working .in our lan it is working. but for remote host it is
> not working remote means host in other lan.
Questions such as this should be sent to nagios-users. You need to say
1 what version of nagios
2 what version of plugin that is 'not working' (run the plugin from the
command line with the -V option and post the output)
3 what you mean by 'not working'
Nagios monitors remote hosts quite effectively by
1 probing tcp services by connecting to the server ports of remote hosts
and checking that the server response is what is expected
2 using the check_ping plugin to find out if the remote host is
reachable
3 running commands or plugins by various methods (eg ssh) on remote
hosts.
> get me some detail about
> this also give some detail about the source code of nagios. because i
> want to learn it and develope nagaios .
> thanking you
Anyone can download the source code from http://www.Nagios.Org/ and read
it for themselves.
This list is for those
1 sending patches to the Nagios source
2 discussing problems/enhancements/understanding the Nagios source
> Regards,
> _____________Exira
> Mohammed Ashraf*
> Software Engineer*
> /*_____________________________*
(# No comment)
Yours sincerely.
Stanley Hopcroft
Network specialist, IT Infrastructure
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.415 (Entity 5.415)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1101444825-49642-6--
