> nap wrote:
>> This is for the circular host check. I use bit 1->5 of
>> host->is_being_freshened. I'm doing now the hostgroup's service patch.
> Thanks a lot! I've mangled the implementation a bit, using macros for
> the most part and accessing host->circular_path_checked instead of
> the higher order bits of is_being_freshened. Since it's now using
> macros, we could re-use this for host- and service dependencies too,
> as those also have the circular_path_checked variable.
Yes, the same algorithm can be use.
> Timing values from a config with 151109 hosts:
> Patched
> 6.28user 0.19system 0:06.58elapsed 98%CPU (0avgtext+0avgdata 0maxresident=
)k
> 0inputs+0outputs (0major+65723minor)pagefaults 0swaps
> Unpatched
> Ctrl-C before it was finished, providing these numbers:
> 3221.77user 0.31system 53:56.51elapsed 99%CPU (0text+0data 0max)k
> 0inputs+0outputs (0major+67480minor)pagefaults 0swaps
> So far, your patch provides a speedup of *at least* 51302%. Very nice
> indeed.
> With a more modest configuration (15000 hosts), Nagios patched with your
> DFS code completes in 0.72 seconds, while vanilla Nagios needs 3m 33s to
> verify it. In short; Your patch cuts configuration verification down to
> 0.3% of what it originally required. I suspect we can get rid of the
> pre-cache thing entirely now. The speedups it provides are really no
> longer enough to warrant the complexities it entails.
> I've also verified with some very strange configurations that it doesn't
> ever miss a circular path chain, and it also prints all elements of a
> circular path even if that chain in itself contains a circular chain.
> Consider this:
> host1 parents: host2
> host2 parents: host1,host3
> host3 parents: host1
> With your patch, all three hosts are printed (as they should). With
> vanilla Nagios, only host1 and host2 are printed. I simplified this
> example a bit, since I just added random circular paths to a customer's
> config when I was testing it out, but it seems your patch is more
> correct while at the same time scaling linearly with the number of
> hosts. Thanks indeed.
Maybe we can take part of my very first email for this patch for the
documentation. I wrote how the patch is working (with the differents
state, etc).
Is the patch ok for the next Nagios version?
Gab=E8s jean
> Andreas Ericsson =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 andreas.ericsson@op5=
.se
> OP5 AB =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 www.op5.se
> Tel: +46 8-230225 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0Fax: +46 8-230231
> Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
> =A0http://nordicmeetonnagios.op5.org/
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
> Crystal Reports - New Free Runtime and 30 Day Trial
> Check out the new simplified licensing option that enables
> unlimited royalty-free distribution of the report engine
> for externally facing server and web deployment.
> http://p.sf.net/sfu/businessobjects
> Nagios-devel mailing list
> [email protected]
