[Nagios-devel] Nagat 1.0a1
Hey!
I'm happy to announce the 1.0a1 GPL release of Nagat (Nagios
Administration Tool). Nagat runs with PHP. And please make backups first
if you gonna risk trying it to run on the live Nagios config :p
http://sourceforge.net/projects/nagat/
I rewrote Nagat (from the previews) so the import/export/save/read
functions are in a somekind of plugin system. If you don't like the
default storage in files as serialized PHP data, you can write your own
using MySQL, Oracle, PostgreSQL, LDAP, etc..
Nagat will export *.cfg files the way it is defined in the plugins. I
hope it works out.
Thanks to Ethan and all people that commented the previews of Nagat.
I will try to follow the versions of Nagios so the compatibility is
clear. The alfa and beta releases will be compatible as much as
possible.
Enjoy!
Regards,
Geert
Geert Vanderkelen
Ypsilon.Net AG
http://www.ypsilon.net
