Andreas Kasenides wrote:
>>> I seem to remember reading something about this some time back,
>>> but my search did not turn anything so here it goes:
>>> I am using Nagios 2.7, ndoutils 1.4b6 and it seems that when I use
>>> several cfg_dir in my nagios.cfg the corresponding table in the DB
>>> (_configvariables) will only retain one record for a cfg_dir (varname
>>> = cfg_dir), the last one.
>>> The exact same thing happens with cfg_file variables.
>>> As far as I can tell this behaviour was the same in ndoutils 1.4b2.
>>> Any idea why?
>> Probably because the column has the "UNIQUE" property. I don't know
>> for sure though, as I don't use ndoutils.
> Oh yes indeed! Thanks a zillion!
> Here is a small "patch" for db/mysql.sql of the offending table that
> fixes it where
> I removed the varname attribute from UNIQUE KEY line.
Thanks. I'll mangle it into a proper patch and submit it on to Ethan.
OP5 AB www.op5.se
