Re: [Nagios-devel] Problems with many hanging Nagios
Ethan Galstad wrote:
> Good work on nailing down the problem to the command buffer slots!
> Sounds like this problem might affect a number of users, so I think we
> need to patch Nagios. There are two possible solutions:
> 1. Bump up the default buffer slots to something larger. Since Nagios
> only immediately allocates memory for pointers, the additional memory
> overhead is fairly small. Allocated memory = (sizeof(char **)) * (# of
> slots).
> 2. Moving the slots definitions out to command file variables. This is
> a better solution than having to edit the code and recompile.
> Thoughts?
3. Make the number of slots dynamic and allocate memory as needed. It
should never release any allocated memory, but just increase the number
of buffer slots as needed. One probably wants to allocate the buffer
slots in chunks of sysconf(_SC_PAGESIZE) / (sizeof(char *)) to keep it
to one page at a time, which will prevent expensive memory copying on
realloc().
OP5 AB www.op5.se
