Hi Stanley,
CC List
I'm sorry if I don't understand what you want me to do. But if I
understand correctly, you want me to recompile Nagios with -g option to
gcc. But if I check the files you pointed me to, it looks like it
allready was the case:
[root@gcclo77 nagios-cvs]# grep CFLAGS Makefile
CFLAGS=-g -O2 -DHAVE_CONFIG_H
[root@gcclo77 nagios-cvs]# grep CFLAGS Makefile.in
CFLAGS=@CFLAGS@ @DEFS@
Environment is Centos 3.1 fully patched (RHEL 3):
[root@gcclo77 nagios-cvs]# gcc -v
Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info --enable-shared --enable-threads=posix
--disable-checking --with-system-zlib --enable-__cxa_atexit
--host=i386-redhat-linux
Thread model: posix
gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-39)
[root@gcclo77 nagios-cvs]# uname -a
Linux gcclo77 2.4.21-15.0.4.ELsmp #1 SMP Wed Aug 4 00:52:17 EDT 2004
i686 i686 i386 GNU/Linux
[root@gcclo77 nagios-cvs]# cat /proc/version
Linux version 2.4.21-15.0.4.ELsmp (skvidal@el) (gcc version 3.2.3
20030502 (Red Hat Linux 3.2.3-34)) #1 SMP Wed Aug 4 00:52:17 EDT 2004
Kind regards,
Tom
Stanley Hopcroft wrote:
>Dear Tom,
>I am writing to thank you for your letter and say,
>On Fri, Sep 03, 2004 at 10:25:30AM +0200, Tom DE BLENDE (GCC) wrote:
>'(no debugging symbols found)' is fatal since it means gdb can't relate
>the fault in the text (binary) with the source.
>It means that Nag was compiled without debugging -g option to gcc.
>In the 1.x series this is defined in the CFLAGS in the Makefile (and
>should be Makefile.in).
>If you stripped the binary (good idea normally), recompile and try
>again.
>Otherwise try putting a -g in the CFLAGs of Makefile.in (prob create a
>backup), recompile and gdb again (you don't need DEBUG options to
>configure nor do you need to install the new binary).
>It's prob not a bad thing to rip out any optimiser options (-O2 etc) if
>you stll get a SEGV and try that also.
>I know this is a lot to ask but it's the only way.
>Best also to post
>OS name and version
>gcc -v
>to Nag-devel along with the bt and the configure options.
>>[root@gcclo77 etc]# gdb ../bin/nagios
>>GNU gdb Red Hat Linux (6.0post-0.20040223.20rh)
>>Copyright 2004 Free Software Foundation, Inc.
>>GDB is free software, covered by the GNU General Public License, and you are
>>welcome to change it and/or distribute copies of it under certain
>>conditions.
>>Type "show copying" to see the conditions.
>>There is absolutely no warranty for GDB. Type "show warranty" for details.
>>This GDB was configured as "i386-redhat-linux-gnu"...(no debugging
>>symbols found)...Using host libthread_db library
>>"/lib/tls/libthread_db.so.1".
>r> (gdb) set args -d /usr/local/nagios/etc/nagios
>>(gdb) r
>>Starting program: /usr/local/nagios/bin/nagios -d
>>(no debugging symbols found)...(no debugging symbols found)...(no
>>debugging symbols found)...(no debugging symbols found)...[Thread
>>debugging using libthread_db enabled]
>>[New Thread -1220216704 (LWP 20093)]
>>debugging symbols found)...(no debugging symbols found)...(no debugging
>>symbols found)...
>>Program exited with code 0376.
>>(gdb) bt
>>No stack.
>>(gdb)
>Nice job. Sorry the information wasn't up to it.
>I can't help with the prob; my focus is (poorly admittedly) with the ePN
>support in 2.x.
>BTW SEGV ==> BUG so you are helping significantly debug the 2.x series.
>Yours sincerely.
