------=_Part_15871_8748389.1140770501261
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Hi all,
When using check_cluster2 for service clusters with two nodes, and one node
is only running at a given time (hearbeat) the services defined for the
inactive host will be critical, and show up in the webgui as critical with
noti disabled. The check_cluster2 check is ok since one of the nodes are ok=
My questions is if it's possible not to show the services for the inactive
node in the webgui?
BR
Robert
Content-Type: text/html; charset=ISO-8859-1
Hi all,When using check_cluster2 for service clusters with two node=
s, and one node is only running at a given time (hearbeat) the services def=
ined for the inactive host will be critical, and show up in the webgui as c=
ritical with noti disabled. The check_cluster2 check is ok since one of the=
nodes are ok.
My questions is if it's possible not to show the services for the i=
nactive node in the webgui?BRRobert
------=_Part_15871_8748389.1140770501261--
