Re: [Nagios-devel] Event handlers functionality reapplied to Nagios
On 02/25/2013 04:31 PM, Ton Voon wrote:
> Andreas,
> We've noticed that the event handlers do not currently work in Nagios
> 4 trunk. It seems that there is a FIXME message where the worker part
> was not implemented.
> We've now implemented this, so I think this is now working as
> expected.
The patch is incomplete. There will be no warnings if the eventhandler
times out, which is what the FIXME comments refer to.
> Please find the patch below, nagios_4_support_event_handlers.patch.
> This applies on top of the envvar support we added for Nagios 4
> (subject "Fix default value for enable_environment_macros") which is
> reattached as nagios_macro_environents_in_command_definition.patch.
> Are there any other things that are not implemented yet that you
> would like some assistance with?
> Ton
Everyone hates slow websites. So do we.
> Make your web apps faster with AppDynamics Download AppDynamics Lite
> for free today: http://p.sf.net/sfu/appdyn_d2d_feb
> _______________________________________________ Nagios-devel mailing
> list [email protected]
OP5 AB www.op5.se
on peace.
