Re: [Nagios-devel] bug: unlocking an invalid mutex
Andreas Ericsson wrote:
> Geert Hendrickx wrote:
>> Hi,
>> I tried to upgrade a Nagios 2.5 system running on NetBSD to Nagios 2.9.
>> But it seems like a mutex bug has been introduced in Nagios 2.7 (I can
>> reproduce it with Nagios 2.7 but not with 2.5 and 2.6).
>> Unlike Linux, NetBSD's pthread implementation is quite unforgiving for
>> mutex errors, and aborts a running program e.g. when it tries to unlock
>> an invalid mutex. This is what is happening with Nagios:
>>> Nagios 2.9 starting... (PID=17620)
>>> nagios: Error detected by libpthread: Invalid mutex.
>>> Detected by file "/cvs/src/3/lib/libpthread/pthread_mutex.c", line 334, function "pthread_mutex_unlock".
>>> See pthread(3) for information.
>>> Program received signal SIGABRT, Aborted.
>>> [Switching to LWP 1]
>>> 0xbd9e921f in kill () from /usr/lib/libc.so.12
>>> (gdb) bt
>>> #0 0xbd9e921f in kill () from /usr/lib/libc.so.12
>>> #1 0xbdaa6fb6 in pthread__errorfunc () from /usr/lib/libpthread.so.0
>>> #2 0xbdaa3d4b in pthread_mutex_unlock () from /usr/lib/libpthread.so.0
>>> #3 0x080a1651 in xsddefault_save_status_data () at ../xdata/xsddefault.c:338
>>> #4 0x080a10bd in update_all_status_data () at ../common/statusdata.c:93
>>> #5 0x080544dc in main (argc=2, argv=0xbfbfe8b8, env=0xbfbfe8c4) at nagios.c:665
>>> #6 0x0805377d in ___start ()
>>> (gdb)
>> The problem is probably in this change between Nagios 2.6 and 2.7:
>> --- xdata/xsddefault.c 2006-05-20 21:39:34.000000000 +0200
>> +++ xdata/xsddefault.c 2007-01-03 03:50:43.000000000 +0100
>> @@ -322,6 +331,18 @@
>> return ERROR;
>> + /* get number of items in the check result buffer */
>> + pthread_mutex_lock(&service_result_buffer.buffer_lock);
>> + used_check_result_buffer_slots=service_result_buffer.items;
>> + high_check_result_buffer_slots=service_result_buffer.high;
>> + pthread_mutex_unlock(&service_result_buffer.buffer_lock);
>> + /* get number of items in the command buffer */
>> + pthread_mutex_lock(&external_command_buffer.buffer_lock);
>> + used_external_command_buffer_slots=external_command_buffer.items;
>> + high_external_command_buffer_slots=external_command_buffer.high;
>> + pthread_mutex_unlock(&external_command_buffer.buffer_lock);
>> /* write version info to status file */
>> fprintf(fp,"########################################\n");
>> fprintf(fp,"# NAGIOS STATUS FILE\n");
>> Can this please be looked into? Do I need to provide more information?
> I suppose just checking for success from the pthread_mutex_lock() calls would
> be enough, and letting it spinlock for 10 tries if it fails. If it *always* fails,
> that would be quite horrible though, as it would mean something fairly illegal is
> going on in there.
> I'll whip up a patch for it once I'm done with what I'm currently fiddling with.
It looks like the error is occurring in the pthread_mutex_unlock()
function, which is strange. Checking Google resulted in a couple of
hits that make it sound like a problem in NetBSD's pthread implementation.
Does the error still occur if you set "PTHREAD_DIAGASSERT='A'" before
starting Nagios up? Here's one article that describes how doing so
fixed a similar error with gftp under NetBSD:
http://bugzilla.gnome.org/show_bug.cgi?id=373411
Ethan Galstad,
Nagios Developer
Email: [email protected]
