Re: [Nagios-devel] MAX_PLUGIN_OUTPUT_LENGHT
[email protected] wrote:
> Hello
> I'm testing nagios 3.0b5. During my tests I try to change maximum plugin
> output as written in documentation.
> It's not working, it seems that some buffers are not defined based
> MAX_PLUGIN_OUTPUT_LENGHT constant.
> Martin
> Martin
Martin - Where are you seeing problems with the buffer length being
clipped short of MAX_PLUGIN_OUTPUT_LENGTH? If that's happening, its a
bug and needs to be fixed.
Ethan Galstad,
Nagios Developer
Email: [email protected]
