[Nagios-devel] PATCH: checks.c
I made this patch for Nagios 2.7 in order to obtain the correct global
service_check_timeout in my DNX NEB Module's NEBTYPE_SERVICECHECK_INITIATE
callback routine.
Even if you don't use DNX, it's probably still a bug to get a zero for the
timeout member of the nebstruct_service_check_data structure.
Here's the patch:
--- ../checks.c-orig 2006-06-20 18:59:19.000000000 -0600
+++ checks.c 2007-02-26 16:23:48.342774672 -0700
@@ -271,7 +271,7 @@
/* send data to event broker */
end_time.tv_sec=0L;
end_time.tv_usec=0L;
broker_service_check(NEBTYPE_SERVICECHECK_INITIATE,NEBFLAG_NONE,NEBATTR_NONE,svc,SERVICE_CHECK_ACTIVE,start_time,end_time,svc->service_check_command,svc->latency,0.0,0,FALSE,0,processed_command,NULL);
broker_service_check(NEBTYPE_SERVICECHECK_INITIATE,NEBFLAG_NONE,NEBATTR_NONE,svc,SERVICE_CHECK_ACTIVE,start_time,end_time,svc->service_check_command,svc->latency,0.0,service_check_timeout,FALSE,0,processed_command,NULL);
#endif
#ifdef EMBEDDEDPERL
Bob
