Re: [Nagios-devel] Patch for schedule downtime reports in avail.cgi.
--------------060502090503010805010606
Content-Type: multipart/alternative;
boundary="------------030103010908040509060403"
--------------030103010908040509060403
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
Attached is the patch like you ask.
[]s.
Andreas Ericsson wrote:
> Alessandro Ren wrote:
>> Attached is a patch for nagios-2.0 final that fixes the problem in
>> avail.cgi that does't show the schedule downtimes in the reports.
>> All changes are done in the function
>> compute_subject_downtime_times in cgi/avail.c code.
>> Any feedbacks on the patch are aprechiated. It is working for me
>> so far.
>> The fixed function can also be appllied to earlier versions, I
>> have also tested in 1.x nagios version and it has worked fine and so
>> in the 2.0 beta versions.
> Could you resend this patch in unified diff format, please?
> Just recreate it with your current directory structure and the command:
> diff -urN nagios-2.0 nagios-2.0-patched > sched-downtime.diff
> and send sched-downtime.diff to the list.
> Thanks
__________________________________________________
*Alessandro Ren*
/*OpServices*/
/*Luciana de Abreu, 471 - Sala 403*/
/*Porto Alegre, RS - CEP 90570-060*/
*(* phone 55(51)3061-3588
*4* fax 55(51)3061-3588
*Q* mobile 55(51)8151-8212
*:* email [email protected]
Content-Type: text/html; charset=ISO-8859-15
Content-Transfer-Encoding: 8bit
    []s.
Alessandro
   All changes are done in the function compute_subject_downtime_times
   Any feedbacks on the patch are aprechiated. It is working for me so
far.
   The fixed function can also be appllied to earlier versions, I have
also tested in 1.x nagios version and it has worked fine and so in the
2.0 beta versions.
OpSign
Alessandro Ren
OpServices
(   phone 55(51)3061-3588
4    fax 55(51)3
...[email truncated]...
