I have Nagios XI 2009R1.4b manually installed on a new installation of CentOS 5.5. I installed LDAP Authentication XI Component
as a wizard thinking it was LDAP Server Nagios XI Monitoring Wizard. After that all links to the configuration wizards disappeared. The only thing I can access is the Core Configuration Manager and any attemps to add hosts result in configuration Verification Failed.
Any ideas how to recover? This was a new install and no backups were made yet.
Links to configuration Wizards disappeared
tonyyarusso
Re: Links to configuration Wizards disappeared
rm -rf /usr/local/nagiosxi/html/includes/configwizards/active_directoryRe: Links to configuration Wizards disappeared
Thank you, thank you, thank you. What actually worked was removing an ldapauth folder from /usr/local/nagiosxi/html/includes/configwizards. Your post gave me enough information to get that done and I appreciate that. I'm like a bull in a china shop when on a Linux box and I couldn't find the location of the configwizards folder.
I probably should add that disappeared is spelled with 2 p's. Thank you again!!!!
Great to hear you got the issue resolved! Do feel free to contact us if you have any questions or issues and we would be glad to help.
(I fixed this for you)espint wrote: I probably should add that disappeared is spelled with 2 p's. Thank you again!!!!
