Re: [Nagios-devel] More Threads Please?
On 8/19/2009 12:58 PM, Hiren Patel wrote:
> Steven D. Morrey wrote:
>> Hello Everyone,
>> I've been profiling Nagios and found that at least on my installation with 30,000+ checks that 60% of the time is spent in reaping events and 3% is spent in saving status and another 1% is spent in writing out retention files.
>> This means that less than 30% is actually spent executing checks, to compound the problem the latency is really, really high and it looks like it's due to high priority events blocking execution.
>> It seems to me that all of these "high priority" events are high priority because they need to run right now, but I don't see why they need to block execution of everything else just to perform housekeeping tasks.
>> Assuming I were to put a mutex on the relevant objects, can anyone foresee a problem with running these high priority events in their own thread or even threads?
>> I have 2 designs in mind.
>> One would be a simple refactor that calls handle_timed_event with pthread create, on the high priority events.
>> This would create a new thread for each high priority event, but would be literally be a change to only a couple lines of code.
>> Another design would call for a breaking the main event loop into a high priority thread and a low priority thread.
>> In this case we would only have 2 threads, we loose a bit of the flexibility (and danger) and of having per event threads for high priority events, we also loose most of the overhead of thread creation.
>> I'm not sure high priority events are frequent enough that thread creation overhead is significant.
>> Anyways, as always your thoughts are very much appreciated.
> I'd be keen to see the difference it makes running high priority events
> in separate threads, I don't know nagios well enough to spot anything
> that might break as a result, but it sounds interesting to try out.
> if option one is easier to implement, I wouldn't mind trying to help
> with this, or testing. I don't have much of a test environment at the
> moment though.
While heavily debuging nagios some time ago, I also think that more
threads would be a nice try.
[]s.
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Nagios-devel mailing list
> [email protected]
