Re: [Nagios-devel] Lock User in Host/Service Acknowledgement Mask
>> Hi there,
>> it would be great if there would be a possibility in cgi.cfg=
or
>> whatever to lock the "Author" Input Field in Host and Service=
>>Acknowledg
>> ements. This would prevent users from faking another users in=
>>this
>> Field.
>Just hack the cgi to display the name and be a hidden input >variable.
>It's not bulletproof, but it at least makes it a pain.
Hi Jeff,
thanks for your answer.
yes this is one possibility that i already used in the past. It=
works fine but i know that there are several other users out there=
which would be happy if this feater would exist by default.
I dont like to modify the nagios sources cause of consistency purposes=
in large environments.
on the logic side its a disagreement to use an authentication method=
for each user and allow them to change a user name in this form.
Maybe can Ethan have a look at this? ;-)
cheers,
Lukas
=09
