Re: [Nagios-devel] Database access via Nagios
On 03/16/2010 07:04 PM, Max wrote:
> Ninja reads Nagios information from the database tables created by
> Merlin, which has both a NEB module and a daemon (merlind) that reads
> from / writes to the NEB module.
A partial truth. Ninja also uses the data stored by reports-module.
Reports-module will be made redundant and its features incorporated
into Merlin at a later stage, but since the reports-module is very
widely tested we've decided to forgo including this feature in
Merlin for the time being.
> The Merlin database schema is very similar to the NDO database schema
> with the addition of some fields to allow for multiple merlin daemons
> to write to a single database (TBD - currently the daemons all use the
> same hardcoded instance ID in the DB).
This isn't true at all though. Merlin's object storage model is a lot
simpler than that of [ni]doutils. We made it that way since this made
it possible to write simpler and much more efficient queries for it,
with the added bonus of being a lot easier to understand.
Some basic testing showed that the ndoutils schema did not scale
linearly with the number of objects monitored. Merlin's schema does.
OP5 AB www.op5.se
on peace.
