[Nagios-devel] Bugfix for host ok on alarm() timeout
--------------010109000003070307080908
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
attached is a path for a bug that occurs if plugins dont quit normally.
Return values aren't processed properly.
Best regards
Percy Jahn
name="signal.patch"
Content-Disposition: inline;
filename="signal.patch"
--- nagios-2-x-cvs/base/utils.c.orig 2007-03-29 15:41:48.000000000 +0200
+++ nagios-2-x-cvs/base/utils.c 2007-03-29 15:47:39.000000000 +0200
@@ -2832,8 +2832,18 @@
/* report an error if we couldn't close the command */
if(status==-1)
result=STATE_CRITICAL;
- else
+ else {
result=WEXITSTATUS(status);
+ if(result==0 && WIFSIGNALED(status)) {
+ /* like bash */
+ result=128 + WTERMSIG(status);
+ snprintf(buffer,sizeof(buffer)-1,
+ "(Plugin received signal %d!)\n", WTERMSIG(status));
+ buffer[sizeof(buffer)-1]='\x0';
+ write(fd[1],buffer,strlen(buffer)+1);
+ buffer[0]='\x0';
/* write the output back to the parent process */
--- nagios-2-x-cvs/base/checks.c.orig 2007-03-29 16:43:12.000000000 +0200
+++ nagios-2-x-cvs/base/checks.c 2007-03-29 16:55:50.000000000 +0200
@@ -523,6 +523,16 @@
svc_msg.exited_ok=FALSE;
svc_msg.early_timeout=FALSE;
+ else if(WEXITSTATUS(pclose_result)==0
+ && WIFSIGNALED(pclose_result) ){
+ snprintf(svc_msg.output,sizeof(svc_msg.output)-1,"(Plugin received signal %d!)\n",WTERMSIG(pclose_result));
+ svc_msg.output[sizeof(svc_msg.output)-1]='\x0';
+ svc_msg.exited_ok=TRUE;
+ svc_msg.early_timeout=FALSE;
+ /* like bash */
+ pclose_result=128+WTERMSIG(pclose_result);
+ svc_msg.return_code=pclose_result;
/* write check result to message queue */
write_svc_message(&svc_msg);
--------------010109000003070307080908--
