On 02/03/2011 11:59 PM, Andreas Ericsson wrote:
> On 02/03/2011 07:53 PM, Ton Voon wrote:
>> From the code, I can see that Nagios does not record any soft
>> non-OK states in this state history. Any objections if I add "host
>> or service in downtime" to that exception?
> None at all. In fact, +1 on doing so. This way, downtime makes all
> effects of statechanges void and null
Umh, not quite, I'm afraid. It means that hosts/services will emerge
from downtime with the history they had when they entered downtime
way-back-when - which may well be the non-OK or FLAPPING which prompted
you to schedule urgent repairs in the first place.
It IIUC also means that during the downtime, the CGI-bins will keep
displaying the *historic* flapping state, along with the *current*
host/service state.
Downtime disables notifications anyway, and there already is logic to
trigger actions when downtime ends (*). IMHO, the proper way to provide
a clean slate after a downtime would be to flush (**) the entire history
at that point.
(*) Notification type "s" - BTW,
http://nagios.sourceforge.net/docs/3_0/ ... ml#contact
lists services-"s" in the Definition Format but not in the Directive
Descriptions.
(**) Whether the bins should be reset to OK, PENDING,
last-before-downtime or the current post-downtime $*STATE$ (if one is
already available) is up for discussion ...
Regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
