Re: [Nagios-devel] Future of Nagios (was Nagios is dead! Long
I'm not sure why anybody thinks Nagios isn't capable of scaling to =20
anything of that size. I'm currently monitoring almost exactly twice =20=
that (60,000 services/6000 hosts) with 6 hosts and the load on every =20
host is well under .5 (most are .1). The _only_ reason I have so many =20=
monitoring hosts is that the network spans 3 physical locations and I =20=
need some redundancy. I'm even using custom perl scripts for a large =20=
portion of the checks and I haven't needed to even consider using the =20=
embedded perl interpreter yet.
On May 6, 2009, at 12:25 PM, Steven D. Morrey wrote:
> DNX is designed to address pretty much what you're asking for there.
> Being the current lead developer on DNX, I am seeing it handle 3000+ =20=
> hosts and 30,000+ services, all using just 3 boxes and we haven't =20
> even begun to saturate CPU or memory so we know we can go a lot =20
> further.
> You should give it a shot, if you have any questions feel free to =20
> ask us on the dnx list [email protected] (to prevent spam, =20
> sign up is required before posting).
> Enjoy!
> Sincerely,
> Steve
> ________________________________________
> From: Mathieu Gagn=E9 [[email protected]]
> Sent: Wednesday, May 06, 2009 12:33 PM
> To: Nagios Developers List
> Subject: [Nagios-devel] Future of Nagios (was Nagios is dead! Long =20
> live Icinga!)
> Hi Ethan,
> First, thank you very much for Nagios.
> Our enterprise relies heavily on it and Nagios has been a great
> monitoring tools for us for so many years. Up to now, nothing has
> surpassed its simplicity of use and we will continue to use it in the
> foreseeable future.
> On 5/6/09 11:56 AM, Ethan Galstad wrote:
>> 4. Big things are coming around the bend for Nagios. Big things take
>> time. Be patient for a bit longer and you'll see the results.
> As an enterprise looking to scale Nagios to tens of thousands =20
> monitored
> hosts and services, what could be our expectations of the future
> regarding scalability?
> We are using NDOutils to centralize host/service status.
> One of our main challenge will be to optimize the configuration and
> patch Nagios/NDOutils to make reloads as fast as possible since =20
> addition
> and removable of monitored hosts have a high turnover rate. (I don't
> know if it's the correct way to say it in English)
> Reloading Nagios so it can pickup the new configuration is viewed as a
> "flaw" by our developers team because there's no monitoring done =20
> during
> that time.
> If we reload Nagios too often, it would simply pass the majority of =20=
> its
> time exporting configuration/status to NDOutils and scheduling checks
> without doing any real work at all. Too seldom and new monitoring =20
> would
> take too much time before being scheduled.
> Any future plan regarding this aspect?
> Also, have you ever heard of DNX? http://dnx.sourceforge.net/
> Any future plan about a similar feature within Nagios?
> Thanks for your time.
> Mathieu
> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! =20=
> Your
> production scanning environment may not be a perfect world - but =20
> thanks to
> Kodak, there's a perfect scanner to get the job done! With the NEW =20
> KODAK i700
> Series Scanner you'll get full speed at 300 dpi even with all image
> processing features enabled. http://p.sf.net/sfu/kodak-com
> Nagios-devel mailing list
> [email protected]
> NOTICE: This email message is for the sole use of the intended =20
> recipient(s) and may contain confidential and privileged =20
> information. Any unauthorized review, use, disclosure or =20
> distribution is prohibited. If you are not the intended recipient, =20
> please contact the sender by reply email and destroy all copies of =20
> the original message.
...[email truncated]...
