RE: [Nagios-devel] avail.cgi timerperiods patch
As I got a question on version and OS for this patch I =
figured I post it to the list as well.
It is against the Nagios 2.0a CVS version, and I have tested it on Linux =
(RedHat 3.0), but I figure it ought to work on all OSes as it doesn't do =
anything strange...
// Michael Medin
-----Original Message-----
Michael Medin
Sent:   Thu 2004-10-21 10:35
To:     [email protected]
Cc:
Subject:        [Nagios-devel] =
This is a simple patch that allows (or so I hope) availability =
reports
to be made based on a time period. What this means is that I can
generate reports for other timeframes then 24x7.
We use this internally to generate availability reports for some of =
our
systems that have an 8x5 SLA. How this works and is implemented is =
that
on the last page of the availability report you can select a =
predefined
timeperiod and then only time during that period is counted towards =
the
avalibility report.
This means that for our SLA which is 9-5 mon-fri I can generate
avalibility reports for that timeframe but still monitor 24x7.
As I stated before I don't know that much about nagios development so =
if
this is implemented badly, have bugs or plain out doesn't work =
please
let me know :)
BTW; the "patch" has been generated with tortouise so it might =
possibly
not follow whatever standard patches should but I could apply it to =
my
Linux box sp hopefully it will work.
// Michael Medin
