[Nagios-devel] Fwd: [PATCH] Fix default value for
--Apple-Mail-76--255155198
Content-Type: text/plain;
charset=us-ascii
Apologies if you receive this twice - resending this as it appears that =
mail from [email protected] appears to be blocked to this mailing =
list.
On 11 Jan 2013, at 17:08, Andreas Ericsson wrote:
> On 01/11/2013 02:43 PM, Ton Voon wrote:
>> 2) an env_macros field is available in all objects to
>> define specifically which environment macros. This is a comma
>> separated list, defaulting to ALL for backwards compatibility
>>=20
>=20
> I was thinking more along the lines of
>=20
> define command {
> env ORACLE_HOME=3D/foo/bar/lala
> env HOST_NAME=3D$HOSTNAME$
> command_name check_something
> command_line /path/to/some-check
>=20
> since that also lets users set variables that aren't exactly Nagios =
related.
I think that's a great idea and better than my proposal.
Conceptually, the environment macros are based on =
plugin/notification/eventhandlers/perfhandler requirements, so putting =
this in a "define command" is more accurate than in "define service".
>=20
>> I'm happy to do some of this work, but will require agreement on the
>> design and some technical assistance.
>>=20
>=20
> If you get the macros to the workers as kvvec key/value pairs like =
this:
>=20
> k=3Denv
> v=3DNAGIOS_(MACRO_NAME)=3Dmacro value
>=20
> then I'll make sure the workers set up the environment properly. I'll
> make an addendum to the worker rules though so the (possibly huge)
> macro values don't have to be passed back to Nagios for every check
> executed.
Please find a patch that is setting the envvars. This sets before =
execution and then unsets at the end. I've only done it for 4 hard coded =
variables - it should be based on this new env property. It's clearly =
not production ready yet.
Are there any kv limits to be aware of?
What I can't work out is how to set the env property in "define =
command". Can you provide some pointers and assistance?
Ton
Content-Disposition: attachment; filename=nagios_worker_macros_research.patch
Content-Type: application/octet-stream;
name="nagios_worker_macros_research.patch"
diff -ur nagios-4.0.20130107/base/checks.c nagios-4.0.20130107.withmacros//base/checks.c
--- nagios-4.0.20130107/base/checks.c 2013-01-11 01:23:09.000000000 +0000
+++ nagios-4.0.20130107.withmacros//base/checks.c 2013-01-14 08:52:03.000000000 +0000
@@ -311,6 +311,13 @@
/* update check statistics */
update_check_stats((scheduled_check == TRUE) ? ACTIVE_SCHEDULED_SERVICE_CHECK_STATS : ACTIVE_ONDEMAND_SERVICE_CHECK_STATS, start_time.tv_sec);
+ /* TODO: Grab only the macros defined in the command definition - this currently forces the first 3 to prove it works*/
+ int free_macro = FALSE;
+ grab_macrox_value_r(&mac, 0, NULL, NULL, &mac.x[0], &free_macro);
+ grab_macrox_value_r(&mac, 1, NULL, NULL, &mac.x[1], &free_macro);
+ grab_macrox_value_r(&mac, 2, NULL, NULL, &mac.x[2], &free_macro);
+ //printf("Setting cmd=%s, %s, %s, %s\n", processed_command, mac.x[0], mac.x[1], mac.x[2]);
/* paw off the check to a worker to run */
runchk_result = wproc_run_check(cr, processed_command, &mac);
if (runchk_result == ERROR) {
@@ -2466,6 +2473,13 @@
update_check_stats((scheduled_check == TRUE) ? ACTIVE_SCHEDULED_HOST_CHECK_STATS : ACTIVE_ONDEMAND_HOST_CHECK_STATS, start_time.tv_sec);
update_check_stats(PARALLEL_HOST_CHECK_STATS, start_time.tv_sec);
logit(NSLOG_RUNTIME_ERROR, TRUE, "Unable to run check for ho
...[email truncated]...
