Re: [Nagios-devel] check_snmp
[email protected] wrote:
> Hi,
> i use nagios version 2.04b and its still working fine. Thanks to all developer !
> But one small problem left.
> I monitor several win and linux servers with check_snmp v 1.57. This works fine.
> But when i try to check our WLAN D-Link Accesspoint by check_snmp i get an
> message in nagios like this: SNMP problem - No data received from host.
Please send questions like these to the nagiosplug-help list instead, so
that others can find the answers in the correct archives. I'll answer it
for you once you've posted it there.
OP5 AB www.op5.se
