[Nagios-devel] patch for nagios 3rc1 - move broker pre call down
--------------090001050305050102090705
Hi!
I've recently joined the Distributed Nagios eXecutor (DNX) team (Oct
'07), and have just gotten around to porting DNX over to Nagios 3.
I've been looking at nagios-3.0rc1, and I can see that a new type of
NEBCALLBACK event has been added - NEBTYPE_SERVICECHECK_ASYNC_PRECHECK.
I also note that the run-time semantics of NEBTYPE_SERVICECHECK_INITIATE
have been modified between Nagios 2.x and 3.x. That is, the INITIATE
check no longer honors the handler's return code.
I have a small wish in the form of a patch to nagios-3.0rc1 that I would
like to suggest. I hope you'll find this change reasonable. The patch
simply moves the call to broker_service_check(
NEBTYPE_SERVICECHECK_INITIATE, ... ) above the code that configures the
temporary check output file and check_results_info structure. This puts
the broker call in a similar relative position in 3.x code as in 2.x
code, except for the check_result_info structure initialization, which
didn't really have to be done before the broker call anyway. In
addition, I moved the code that honors the CALLBACKOVERRIDE return value
down to the INITIATE check, but left the code that honors the newer
CALLBACKCANCEL in the ASYNC_PRECHECK check.
This grants two advantages that I can see:
1. It makes Nagios 2.x modules more portable because Nagios 3.x would
honor the same NEB module return values they did in Nagios 2.x code for
the INITATE check. In addition, it provides the useful ability for
Nagios 3.x modules to cancel a check in the PRECHECK handler where it
makes sense to do very little preprocessing before canceling the check;
cancelling the check in the INITIATE handler is less efficient.
2. NEB modules that want to handle the check themselves with the
CALLBACKOVERRIDE return value are going to have trouble processing
macros the same way that Nagios does, unless Nagios provides some API
routines to do it for them. It makes more sense (IMHO) to have the
CALLBACKOVERRIDE honored by the INITIATE check, rather than the
I'm hoping (if you all approve of this change), that we can get it into
the Nagios 3.0 code base before 3.0 ships. Would it be too late for that?
Regards,
John
PS. The patch also fixes a minor error path memory leak, where the
raw_command string was not being freed in case of an out-of-memory
condition while allocating the processed_command buffer.
name="nagios-3.0rc1-dnx.patch"
Content-Disposition: inline;
filename="nagios-3.0rc1-dnx.patch"
diff -Naur nagios-3.0rc1/base/checks.c nagios-3.0rc1-patched/base/checks.c
--- nagios-3.0rc1/base/checks.c 2007-12-12 11:39:46.000000000 -0700
+++ nagios-3.0rc1-patched/base/checks.c 2008-01-18 11:49:24.000000000 -0700
@@ -380,11 +380,6 @@
*preferred_time+=(svc->check_interval*interval_length);
return ERROR;
- /* neb module wants to override the service check - perhaps it will check the service itself */
- /* NOTE: if a module does this, it has to do a lot of the stuff found below to make sure things don't get whacked out of shape! */
- if(neb_result==NEBERROR_CALLBACKOVERRIDE)
- return OK;
#endif
@@ -431,6 +426,19 @@
/* set the execution flag */
svc->is_executing=TRUE;
+#ifdef USE_EVENT_BROKER
+ /* send data to event broker */
+ neb_result=broker_service_check(NEBTYPE_SERVICECHECK_INITIATE,NEBFLAG_NONE,NEBATTR_NONE,svc,SERVICE_CHECK_ACTIVE,start_time,end_time,svc->service_check_command,svc->latency,0.0,service_check_timeout,FALSE,0,processed_command,NULL);
+ /* neb module wants to override the service check - perhaps it will check the service itself */
+ if(neb_result==NEBERROR_CALLBACKOVERRIDE){
+ svc->latency=old_latency;
+ my_free(processed_command);
+ my_free(raw_command);
+ return OK;
+#endif
/* open a temp file for storing check output */
old_umask=umask(new_umask);
asprintf(&output_file,"%s/checkXXXXXX",t
...[email truncated]...
