I use the nsclient++ plugin to query the resources of windows servers and have had good luck with this until now.
I installed the nsclient++ to a new server and some of the checks return with a time out error.
When I schedule an immediate check I get the following entries in the logs:
External Command 2011-03-04 10:07:31EXTERNAL COMMAND: SCHEDULE_SVC_CHECK;DeltekWebProd;Processor Interrupts per Sec;1299251245
External Command 2011-03-04 10:07:09EXTERNAL COMMAND: SCHEDULE_SVC_CHECK;DeltekWebProd;Memory pct Commited Bytes In Use;1299251225
External Command 2011-03-04 10:06:51EXTERNAL COMMAND: SCHEDULE_SVC_CHECK;DeltekWebProd;Memory Pages per Sec - read from disk;1299251208
External Command 2011-03-04 10:06:14EXTERNAL COMMAND: SCHEDULE_SVC_CHECK;DeltekWebProd;Processor pct Busy;1299251170
External Command 2011-03-04 10:05:58EXTERNAL COMMAND: SCHEDULE_SVC_CHECK;DeltekWebProd;System Threads;1299251154
External Command 2011-03-04 10:05:37EXTERNAL COMMAND: SCHEDULE_SVC_CHECK;DeltekWebProd;Memory Pages per Sec - read from disk;1299251131
Any suggestions.
Sal Polifemo
nsclient++ check not returning consistent results
Re: nsclient++ check not returning consistent results
Hello Sal,
did you use/edit the same "nsc.ini" configuration as on previous servers?
Good catch,
I replaced the ini file with fresh copy and all the checks are now working properly.
Thanks for the help
Sal
Thanks for the help
Sal
Glad I could help!
