Re: [Nagios-devel] [Fwd: Nagios 2b3 Error]
Austin, the correct forum would have been the nagios-users mailinglist
as this is not a bug but a user error. See below for details.
Karl DeBisschop wrote:
> -------- Original Message --------
> Subject: Nagios 2b3 Error
> Date: Thu, 21 Apr 2005 17:20:14 -0700
> From: Pittman, Austin
> To: [email protected]
> I am not sure if you are the proper person to send this info to, but I
> couldn't find any contact information on nagios.org.
> I am setting up a Distributed system on Nagios 2b3, when the Distributed
> server sends the check to the central server the 4th feild (information)
> fails.
> Here is the information the central server is seeing.
> [1113886121] EXTERNAL COMMAND:
> PROCESS_SERVICE_CHECK_RESULT;app04;/opt;0;$OUTPUT$
> Notice the $OUTPUT$ for the information field.
Notice the 2.x ChangeLog which states that some macros have changed, and
notice the macro documentation which no longer mentions $OUTPUT$ but
rather splits it into $HOSTOUTPUT$ and $SERVICEOUTPUT$ so as to make
output from hostvchecks available in service notifications as well.
> To verify I was setting the system up correctly, I installed nagios1.3 and
> everything worked.
Naturally, because the macro you're using is correct for the 1.x series
of Nagios.
> Just wanted to let you guys know.
OP5 AB www.op5.se
Lead Developer
