Re: [Nagios-devel] Support quoting vertical bar (|) character in
On 26.03.2013 18:23, Jim Winkle wrote:
> It's possible for a plugin to have a vertical bar (|) character in its
> regular output.
That depends a bit on what your definition of "(plugin) output" is.
Plugins certainly *can* shove pipe symbols out their stdout/stderr, but
(lacking any defined escaping) they'll never arrive in what Nagios
considers the "Plugin Output" (while extraneous pipes *will* appear in
the Performance Data).
> For example, I've seen cases where check_logfiles does this [...]
> It seems that (and correct me if I'm wrong) Nagios doesn't support a
> way to escape '|' in plugin output.
That's correct as of 3.x. (Somebody please speak up if the upcoming 4.x
is going to change that.)
> If this is true, I'll request this enhancement on tracker.nagios.org.
IIUC API changes wouldn't get applied until at least 4.1, so you might
want to simultaneously ask Gerhard for a fix in the plugin for the time
being.
Regards,
J. Bern
--=20
*NEU* - NEC IT-Infrastruktur-Produkte im :
Server--Storage--Virtualisierung--Management SW--Passion for Performance
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
