On 12/15/2010 07:06 PM, Rodney Ramos wrote:
> At the documentation I found:
> "If you do not specify a value for the *freshness_threshold* option
> (that is my case), [...]"
Please verify in your var/objects.cache that the service's
freshness_threshold is indeed (un)set to 0. (You might want to
doublecheck the other relevant parameters, too, while you're there.) If
it isn't, you likely have it set to non-zero in some template.
Kind regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
