Re: [Nagios-devel] Unable to stop executing checks with 3.2.2
See my email re: "test failure with latest code". My guess is that
line referenced in that email is the one causing the problem.
On 10 Sep 2010, at 12:22, Sven Nierlein wrote:
> Hi,
> It seems like with 3.2.2 the
> execute_service_checks=0
> and
> execute_host_checks=0
> setting has no effect anymore.
> Its easy to reproduce. Install a clean 3.2.2 tarball with the
> default config and set both values to 0.
> Then start nagios and after a few moments it starts some checks. The
> webinterface still displays:
> Service Checks Being Executed? NO
> Host Checks Being Executed? NO
> I had a quick look at the patches since 3.2.1 but could not find the
> reason.
> This is the interesting part from the nagios.debug logfile:
> [1284124694.798033] [008.1] [pid=9046] ** Event Check Loop
> [1284124694.798203] [008.1] [pid=9046] Next High Priority Event
> Time: Fri Sep 10 15:18:18 2010
> [1284124694.798261] [008.1] [pid=9046] Next Low Priority Event
> Time: Fri Sep 10 15:18:15 2010
> [1284124694.798307] [008.1] [pid=9046] Current/Max Service Checks: 0/0
> [1284124694.798349] [008.2] [pid=9046] No events to execute at the
> moment. Idling for a bit...
> [1284124694.798393] [001.0] [pid=9046] check_for_external_commands()
> [1284124694.798442] [064.1] [pid=9046] Making callbacks (type 8)...
> [1284124695.048890] [008.1] [pid=9046] ** Event Check Loop
> [1284124695.048988] [008.1] [pid=9046] Next High Priority Event
> [1284124695.049016] [008.1] [pid=9046] Next Low Priority Event
> [1284124695.049038] [008.1] [pid=9046] Current/Max Service Checks: 0/0
> [1284124695.049060] [024.1] [pid=9046] We're not executing service
> checks right now, so we'll skip this event.
> [1284124695.049081] [001.0] [pid=9046] remove_event()
> [1284124695.049104] [064.1] [pid=9046] Making callbacks (type 8)...
> [1284124695.049125] [001.0] [pid=9046] reschedule_event()
> [1284124695.049178] [001.0] [pid=9046] add_event()
> [1284124695.049201] [064.1] [pid=9046] Making callbacks (type 8)...
> [1284124695.049224] [064.1] [pid=9046] Making callbacks (type 20)...
> [1284124695.049245] [008.1] [pid=9046] Running event...
> [1284124695.049266] [001.0] [pid=9046] handle_timed_event() start
> [1284124695.049288] [064.1] [pid=9046] Making callbacks (type 8)...
> [1284124695.049317] [008.0] [pid=9046] ** Timed Event ** Type: 0,
> Run Time: Fri Sep 10 15:18:53 2010
> [1284124695.049342] [008.0] [pid=9046] ** Service Check Event ==>
> Host: 'localhost', Service: 'Current Users', Options: 0, Latency:
> -37.951000 sec
> [1284124695.049371] [001.0] [pid=9046] run_scheduled_service_check()
> start
> [1284124695.049392] [016.0] [pid=9046] Attempting to run scheduled
> check of service 'Current Users' on host 'localhost': check
> options=0, latency=-37.951000
> [1284124695.049442] [001.0] [pid=9046] run_async_service_check()
> [1284124695.049476] [001.0] [pid=9046] check_service_check_viability()
> [1284124695.049509] [001.0] [pid=9046] check_time_against_period()
> [1284124695.049538] [001.0] [pid=9046] check_service_dependencies()
> [1284124695.049584] [064.1] [pid=9046] Making callbacks (type 13)...
> [1284124695.049607] [016.0] [pid=9046] Checking service 'Current
> Users' on host 'localhost'...
> [1284124695.049656] [001.0] [pid=9046] get_raw_command_line()
> Regards,
> Sven
> Automate Storage Tiering Simply
> Optimize IT performance and efficiency through flexible, powerful,
> automated storage tiering capabilities. View this brief to learn how
> you can reduce costs and improve performance.
> http://p.sf.net/sfu/dell-sfdev2dev
> Nagios-devel mailing list
> [email protected]
