Re: [Nagios-devel] OSX processor usage
saggau wrote:
> Hello folks. Long - time Nagios user. I hope this is the right place
> to report a bug + a fix.
> I ran into a (possible) bug in OS X 10.5.4, which I tracked-down to
> poll() never timing out in the cmd file worker thread on that
> platform. It looks like poll() always returns 1, whether there is
> data on the pipe or not. A quick fix that shouldn't break Nagios on
> other platforms and which doesn't require any configure checking of
> poll() is to manually pause if poll() returns 1 with an empty pipe.
> Much much longer description here:
> http://www.jonathansaggau.com/blog/2008 ... trace.html
> Cheers,
> Jonathan Saggau
Nice article! I implemented the patch you suggested.
William's select() patch was also an option, but I seem to remember
there being a bug under Solaris, and/or different Linux distros that
caused the switch to poll().
- Ethan Galstad
