Ok Where did Disable Global Notifications go
fmpub
Post by fmpub »
So new XI new AJAX-Y TAC problem is I am doing work on multiple servers and want to just disable ALL nagios Notifications for a bit... try and click the "ENABLE" graphic to get the option to DISABLE it... but now I get sent to a monitoring process and queue screen with no disable notifications button that I can find.
How do I do this now?
fmpub
Re: Ok Where did Disable Global Notifications go
Post by fmpub »
For now even if you guys could throw me a direct link? that would help
rdedon
Post by rdedon »
It should turn into a "check mark" to re-enable:
http://[servername-IP]/nagiosxi/includes/components/xicore/status.php?show=process#
Which browser are you using?
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
fmpub
Post by fmpub »
Ah yes... I see it now under the Monitoring Engine Process.... changed from the old school dedicate old HTML page :) Thanks for the reply
rdedon
Post by rdedon »
My pleasure and feel free to post if you have any questions or issues :-)
Rene deDon
Technical Team
___
