Devin Bayer wrote:
> Hello:
> We faced an issue when nagios silently failed to fork. Since it's
> part of our startup scripts, this delayed the rest of the daemons
> until nagios exited. For this reason nagios should take care, that if
> it doesn't daemonize correctly, it should die. We are using nagios
> 3.0.5, but I see the bug still exists in the trunk. Here is our
> nagios.log showing the problem:
> [1242115575] Nagios 3.0.5 starting... (PID=773)
> [1242115575] Local time is Tue May 12 11:06:15 EEST 2009
> [1242115575] LOG VERSION: 2.0
> [1242115575] Finished daemonizing... (New PID=773)
> Notice the "New PID" equals the old PID. I think this is the problem
> code, from base/utils.c:
> 2036 : /* check for SIGHUP */
> 2037 : if(val==1 && (pid=(pid_t)pidno)==getpid()){
> 2038 : close(lockfile);
> 2039 : return OK;
> 2040 : }
> If nagios is started at boot time, it's somewhat likely it will have
> about the same PID on the next boot. So if the lockfile isn't cleaned
> for some reason, then nagios will start, read the lockfile, and not
> fork.
> 2042 : /* exit on errors... */
> 2043 : if((pid=fork()) 2044 : return(ERROR);
> This looks like another bug. If fork fails, we return ERROR, but the
> return code is just silently ignored.
> Thanks,
> Devin
Thanks for the report - this will be fixed in CVS shortly...
- Ethan Galstad
