------=_NextPart_000_001A_01CDF23A.AA1C78B0
Content-Type: text/plain;
charset="iso-8859-1"
Hello everybody
First, I don=B4t know if this is the most appropriate list to send this
message because I=92m not a developer but I=92ve send it to the =
nagios-user list
but I have not gotten any response,=85
I would like to use the external command change_svc_check_command to =
change
dinamically the warning and critical values of the checks.=20
However it doesn=B4t work
I think the cause that it doesn't work is the modification introduced in =
the
version 3.0.6 (Disabled adaptive check and eventhandler commands for
security reasons ) as you can see in the URL:
http://www.nagios.org/projects/nagiosco ... ry/core-3x
=20
I=92m using the 3.2.1 version.=20
In this version and also in the latest version 3.4.3, I can see the next
source code in the base/commands.c file
/* SECURITY PATCH - disable these for the time being */
switch(cmd) {
case CMD_CHANGE_GLOBAL_HOST_EVENT_HANDLER:
case CMD_CHANGE_GLOBAL_SVC_EVENT_HANDLER:
case CMD_CHANGE_HOST_EVENT_HANDLER:
case CMD_CHANGE_SVC_EVENT_HANDLER:
case CMD_CHANGE_HOST_CHECK_COMMAND:
case CMD_CHANGE_SVC_CHECK_COMMAND:
return ERROR;
I guess if I delete the above code, the external command
change_svc_check_command will work
Is not recommended to enable this external command?
Why was it disabled in the version 3.0.6? This is not resolved in the =
latest
version?
I haven=B4t found any official documentation about this
=20
Content-Type: text/html;
Hello everybodyFirst, I don=B4t know if this is =
the most appropriate list to send this message because I’m not a =
developer but I’ve send it to the nagios-user list but I have not =
gotten any response,…I would like to use the external =
command change_svc_check_command to change dinamically the warning and =
critical values of the checks. However it doesn=B4t workI think =
the cause that it doesn't work is the modification introduced in the =
...[email truncated]...
