Daniel Drown submitted a patch a few months (or more) back to add
chained hash support for speeding up searches. His patch (with
alterations) has been incorporated into the 2.0 code and results in
major speedups in the CGIs, so that's probably good enough for now
(considering the CGIs will go away in 3.0).
On 5 Sep 2003 at 12:01, David Parrish wrote:
> Attached is another patch to Nagios 1.1 which hugely speeds up the
> CGIs. This is a big benefit when monitoring a lot (~ 7000) of
> services, but there will be a benefit for a smaller number too.
> Profiling shows that most of the time taken to run the CGI is in
> loading the list of services and sticking them into a sorted list.
> This patch turns loading the service list into a 2 step process:
> 1. Load the services into a binary tree (glib)
> 2. Flatten the tree down into the sorted list.
> Before, the CGI took between 3-10 seconds to run, now it takes 0.2
> seconds.
> FYI I didn't write this patch, my boss did. I'm just submitting it.
> Regards,
> David Parrish
> 0410 586 121
Ethan Galstad,
Nagios Developer
Email: [email protected]
