--------------080105080904080708070307
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
Maintaining it would not be an issue. The changes would be tracked in a
VCS and upgrades are unlikely, but an alternative (cleaner) approach
would be interesting.
I am brand new to C but have experience with several other languages,
and have never heard of nagios before yesterday. Could you give me a
more newb friendly suggestion to your approach?
I really appreciate the suggestions so far,
Phil Sturgeon
Andreas Ericsson wrote:
> On 12/06/2010 11:41 PM, Phil Sturgeon wrote:
>> I've been charged with a mission a little outside of my usual skillset, and that is to get Nagios 3.2.3 running from config based on a PostgreSQL table instead of the normal cnf_dir setting. I can work out the actual code for this but im struggling to find /where/ it should go.
>> I have only found one instance of cnf_dir in the source and that is here:
>> else if(strstr(input,"cfg_file=")==input || strstr(input,"cfg_dir=")==input)
>> continue;
>> in config.c line 1328. I have no problems hacking the core, but where do I start?
> Unless you want to maintain it yourself indefinitely, you don't. You could write
> an eventbroker module that loads the configuration by creating all the hosts
> and services you need though. You'll want the NEBCALLBACK_PROGRAM_STATUS events,
> and the NEBTYPE_PROCESS_START type.
Content-Type: text/html; charset=ISO-8859-15
in a VCS and upgrades are unlikely, but an alternative (cleaner)
approach would be interesting.
languages, and have never heard of nagios before yesterday. Could
you give me a more newb friendly suggestion to your approach?
Phil Sturgeon
continue;
--------------080105080904080708070307--
