[Nagios-devel] warning/critical directives
Hi list,
a few days ago I had to mail one of our costumers there warning critical
values for all his services. That was a really boring job :-(.
For such future tasks it would be very helpful if there could be two
optional directives "warning" and "critical". Both should be:
- used be readable by macros ("$WARNING$","$CRITICAL$") to easily
configure the commands
- stored inside the object cache
- columns inside the configuration report through the webinterface.
an example:
host_name foo
service_description smtp
check_command check_smtp
warning 10
critical 15
command_name check_smtp
command_line $USER1$/check_smtp $HOSTADDRESS$ -w $WARNING$ -c
$CRITICAL$
OK, that won't improve nagios functional ;-) but it won't be so much
work to document then.
Any comments? Any volunteers for coding?
Chers,
Gerd
