Re: [Nagios-devel] netutils use of socket descriptor
* Thomas Guyot-Sionnest [2009-06-17 16:18]:
> While the above patch doesn't change any behavior, I was wondering if it
> could loop in case we get a mix of IPv4/v6 addresses and one of the two
> isn't supported. It looks like it would return EINVAL (Unknown protocol,
> or protocol family not available.) in that case, but I'm not experienced
> at all in sockets...
The getaddrinfo(3) call will currently provide IPv4 addresses only, as
hints.ai_family is set to PF_INET. Of course, it would be nice if this
could be changed in order to support IPv6, too. But even then, I don't
see a reason to handle EINVAL (or EPROTONOSUPPORT) specially. Simply
loop over all available addresses and use the first one that works,
regardless of why any others don't work.
Holger
